Please Wait :(
Please Wait :(
Everything is up to date the only thing it will load is the stock tune. just spins round and round for Diablo or my custom tune. I can choose what i want, but just hangs at preparing your tune.
Re: Please Wait :(
please post the info.xml file from the T2 drive.
Re: Please Wait :(
Here you go fine sir, I got it to work finally, My custom tune disappears after I install once and go back to stock tune or the Diablo is that normal, and if I add it again the T2 says it is already loaded. These T2's seem buggy as hell, maybe just me or mine?
Also after switching to a 3.70 from a 3.09 ratio Trans is really not liking it. I put perf tcm tune in and is jerky in traffic and at low speeds, stock is better. Will I have to get a special tune somewhere? My 0-60 is better, but over all I am slower in time and speed for the 1/4.
Thank you Diablo and Hemi Fever for all the Voo Doo you do
Re: Please Wait :(
did you program for the new gear ratio in the quick adjust menu?
So the custom tune was able to be loaded now?
Re: Please Wait :(
[quote="mikel"]did you program for the new gear ratio in the quick adjust menu?
TCM seem much better with stock tune, Next time at track I will know for sure. But feels like converter is the issue in tune. Not sure if it has to do with the adaptive part of the stock tune, Does your TCM tune still have adaptive learning? I was told that changing ratio is not needed cos speed is taken front wheels.
