data logging problems
dicruse
Post by dicruse »
hi, need help with data logging!! everytime I try a log, I get no live PIDs on the tool, only 3 anologue resuts come up on the reader. the only thing showing on the tools screen is a small dot in the centre! have reset to default PIDs countless times, have run ignition updater several times and the tool is up to date, have tried installing seperate PIDs and selecting all still no joy... has anybody had the same problem?
Re: data logging problems
please post the info.xml file from the intune drive.
dicruse
Post by dicruse »
thanks for the response
info.xml
(1.89 KiB) Downloaded 327 times
the device is up to date, not sure if this is a device or vehicle issue at this point.
I see you are tuning an 05 Chrysler, what is it specifically?
dicruse
Post by dicruse »
hi Mikel,
info file sent as requested, no reply!
dicruse
Post by dicruse »
my mistake, didnt see your reply! 2005 dodge magnum sxt v6, had no problem in the past with logging, seems only to have happened since updating with ignition, took a log before that for the original custom tune, now I cant log to have it tweaked, any way to wind back the update?
when did you update it?
dicruse
Post by dicruse »
less than a week ago
dicruse
Post by dicruse »
