8 speed transmission 2014 ram 1500 5.7
Boosted Motorsports
Re: 8 speed transmission 2014 ram 1500 5.7
Post by Boosted Motorsports »
I tried it twice and it failed both times. I have to double check exactly the wording of the stage but you probably know what im talking about from this. There is two "write" processes for the TCM one that takes probably a couple minutes and then the final one that seems to zip through in less than a minute. Its the second and final stage after it hits 99% that says it failed. I can try again tonight and let you know the process names that it gets through or if you want the .xml ?
just the xml for now.
Boosted Motorsports
Here you go! Let me know what to do next to get this baby to work! :evil_angel:
Boosted Motorsports
Here is a bit more info. Also forgot to mention it throws a CEL saying communications lost that I have to clear to get rid of the light. Just tried it again for fun...
Boosted Motorsports
Any more info on the logs I posted? :punisher:
sorry for the delay.
Please post the files from the runtime folder on the i2 drive so we can see what happening.
Boosted Motorsports
Here are all the files in the RUNTIME folder. Let me know what the next step is! :mrgreen:
Boosted Motorsports
Haven't heard anything back since uploading those files for you guys? Whats the update?
Boosted Motorsports
Mike I need you guys to address this right away! I currently can't restore my truck back to stock and remove the DiabloSport tune which is what I have decided to do at this point and go a different route unless there is some news on this.
what happens when you try to restore?
Boosted Motorsports
I get an error saying tune writing failed and then multiple CEL that I have to go back and clear manually. (See attached)
I just want to remove the diablosport at this point. I'm ready to move on with other options unless there is a solution.
Big horn
Post by Big horn »
I just updated my intune. I was the one who created this post lol I'm excited about it but I'm kinda afraid to try it. I see boostedmotorsports is having trouble. I will give the trans tune a try and see what happens. As long as my truck runs at the end I'm fine.
Big horn
Post by Big horn »
It worked fine. I used the i2. The perf trans tune helped my truck so much. Thanks everyone!
Big horn wrote:It worked fine. I used the i2. The perf trans tune helped my truck so much. Thanks everyone!
good to hear.
14_Ram
Post by 14_Ram »
How can we tell if our 14 Ram is able to get the transmission tune?
