14 Srt8 charger no adjustments after update
jgaul19
Post by jgaul19 »
I just received my PCM, TCM, and tuner back from Diablo. Had an issue loading a tune and they needed to be reset. Now I have loaded the 93 tune but the only thing I can change is tire size and to reset the TCM. there are no adjustments that I can find anywhere for throttle boost, MDS shut off, or adjusting shift firmness.
CAN someone at Diablo help me????
Re: 14 Srt8 charger no adjustments after update
definitely looking in the modify parameter menu under advanced tune, not the quick adjust menu?
tripmine56
Post by tripmine56 »
Yeah I cannot find mine again. Can you give a step by step to Advanced settings? Should have been in the manual btw.
Tune Vehicle - Advanced Mode - select the tune you want to install.. then it should ask you if you want to Modify it.. select YES to modify it, and you should get to the Modify Tune menu...
