China special edition wanna use diablo
frog19871230
Post by frog19871230 »
Dear mikel
my frend has a chrysler 2016 300 with 3.0L Pentastar V6(gas). this vehicl is special edition for china. he has changed the engine to the 3.6L Pentastar V6,but can not match the pmc program.we have tryed lots of chrysler oe pmc program with 3.6L,but failed. I think that there must be something different with the different vehicl sells in diferent countrys. For example, we have tryed use the pcm program running on 300, which sells in U.S. but the abs shows not work. other oe program shows other diferent problem , even can not start the engine .
I told my frend that diablo may have the way to solve this problem. because i1000 works very good on my 2013 chrysler 300 3.6L.
My frend worry that his vin shows his vehicl with 3.0L Pentastar,then diablo also give him the diablo pcm tune of 3.0L.
Looking forward to your reply!
Re: China special edition wanna use diablo
I bet I can fix the ABS with the PCM that runs the car but has an ABS issue.
Its usually a simple matter of fixing the displacement scalar to match what the car was configured with.
Send me the tune files once you program that pcm and I will try to fix it.
frog19871230
mikel wrote:I bet I can fix the ABS with the PCM that runs the car but has an ABS issue.
thanks mikle, I will tell him this good news. he should buy a diablo i3 first, right? hahaha, and he will contact U when he get the tune.
thanks again. He will buy it soon. maybe 1 month later, diablo i3 will be deliveried to him at zigong china.
frog19871230
mikel , which model of i3 should I choose,8300 or 8345? I know 8345 required the modified pcm, but my friend do not want to change pcm.
you need the 8345 to support the custom tune I was going to provide, but if he doesnt want to change the pcm then he doesn't want to tune the vehicle and will have to live with the light, as you cannot tune 15+ Chrysler models without modifying the PCM.
frog19871230
mikel wrote:you need the 8345 to support the custom tune I was going to provide, but if he doesnt want to change the pcm then he doesn't want to tune the vehicle and will have to live with the light, as you cannot tune 15+ Chrysler models without modifying the PCM.
thanks mikel !!
frog19871230
thx mikel. diablo have already worked very well on his vihicle without any issue report! thx sooooooo much!
