What happend?
tripmine56
What happend?
Post by tripmine56 »
I had a t1000 for my old car. Got new car bought th i3. What happend to all the adjustments? Sad the old one had way more advanced setting then the new one. Feeling a little robbed. And there is only the 91 octane loaded on there also? What happend to shift points? what happend to spark and what not? Is there something wrong with my !3? Cause I'm feeling robbed big time compared to the old out dated trinty. Sad anyone else limited on theres?
Re: What happend?
both have the same available parameters and tunes....
Are you using the advanced menu on the i3 and going to the modify parameter menu?
If using easy tune you will indeed see limited options.
Re: What happend?
What is the new car - year, engine, tranny?? not all vehicles have the same adjustments available...
Also, did you get the inTune i3 8245 Platinum tool, or the regular inTune i3 8200???
the regular inTune i3 8200 has limited adjustments available, because it's a 50-state legal version tool.. it doesn't have as many adjustments available as the inTune i3 8245 Platinum.
tripmine56
Re: What happend?
Everything looks good now. But the MDS seems to stay on when turned off.
Kingman12
Re: What happend?
Post by Kingman12 »
I have the intune i3 8320. I was under the impression that this i3 tuner had spark timing, rich/lean fuel adjustment, idle rpm etc. why is it advertised that it has it? https://www.diablosport.com/shop/i3-pcm ... 15-v8.html
Return to “General Support”
