Ram 1500 E fan swap.
I am about to do an efan swap and delete the clutch fan on my 16 ram 1500. My question is what temp should I set the fan to cut on at with the stock thermostat. I know factory is 222 degrees but that is just to cut on the small a/c fan to help the clutch fan.
Re: Ram 1500 E fan swap.
you wont have control of it I wouldn't imagine.
Post your backup and I can look at hos the file is set up to see if the efan can be enabled.
It can be done through my custom tune but should I be able to control it with the tuner? I have an ECT fan option. Also I do not have disable traction under quick adjust like I use to have. I updated it and now its gone. I included the backup for the fan adjust and will also post the info.xml to see where my quick adjust options. Thanks in advance.
you'll want to post the last tune written so I can edit that file.
Is that to adjust the fan or the traction? They seem to be able to control the fan and the traction via custom tune. I just wanted the traction disable under quick adjust again so when I cycle the key it is enabled again. Is that possible? They have the fan set perfect now via my custom tune.
I'll need to look into the TC disable, nothing has changed there so it should still be there.
Not sure what the deal is it only shows tires under quick adjust. I’m hoping I can get it back soon. Kinda main reason I got it. All was good until I updated to 8 speed support. Initially it did it on my t1000 and carried over to the t2 when I switched to it.
ok here is the last tunes written. Currently in the truck.
