Recall for pcm
Big Wigg
Recall for pcm
Post by Big Wigg »
I’m gonna put this question up so others can get the info.
So I just received a recall letter in the mail stating I need to have my pcm reflashed for cruise control issue. Do I put the stock one back in the truck to reflash it or do I let them flash the unlocked one. If they flash the unlocked one will it screw it up? Do I just restore the unlocked one to original backup?
If I have to put stock one in how will my unlocked pcm get the update? Thanks for the help just trying to make sure I get this done correctly.
Re: Recall for pcm
doesnt matter either way really, the changes are in the BCM for cruise control.
Big Wigg
Re: Recall for pcm
Post by Big Wigg »
So I can just set it back to stock and it won’t lock it out if they decide to do something with the pcm? Is the trailer brake in the pcm or back?
Re: Recall for pcm
they cant lock it out really, you'll be fine.
Easy solution is to put stock pcm in, let them flash it then put tuned pcm back in when you get back.
Big Wigg
Re: Recall for pcm
Post by Big Wigg »
What if I need the new update in the unlocked pcm? Do you guys provide that?
Re: Recall for pcm
no, the updated cal is not directly supported so we do not load it to pcms here.
