Recalls and diablo PCMs
Mrdazana
Post by Mrdazana »
I purchased a diablo PCM for my truck (2016 ram 1500) and keep the original when I go to the dealer. I recieved this update on the stock PCM for the cruise control the other day. If I put back the Diablo PCM am i safe ? Do we get updates for our diablo PCM's to fix this issue ?
Mrdazana
Re: Recalls and diablo PCMs
Post by Mrdazana »
Bump.....
the fix for cruise is in a different module, the pcm swap should not have any effect.
Nightshade
Post by Nightshade »
mikel wrote:the fix for cruise is in a different module, the pcm swap should not have any effect.
Are you sure? What happens if someone goes in for the recall and they flash the unlocked PCM with new code?
According to the U61 recall:
The fault handling strategy of the Powertrain Control Module (PCM) software on your vehicle [1] does not remove positive torque requests from the engine controller if the CAN-C bus stops communicating while the cruise control is requesting positive torque. In the instance of a short in the vehicle causing the CAN-C bus to stop communicating while the cruise control is active and the vehicle speed is below the set speed such that the cruise control system is requesting positive torque at the exact moment of the short, it is possible for a positive torque request to be locked on the PCM which may result in either the vehicle maintaining its current speed or possibly accelerating. If the driver does not shift to neutral or apply the brakes to stop the vehicle this condition can cause a vehicle crash without warning.
Remedy
Chrysler will notify owners, and dealers will inspect the software, and perform a software flash on the engine or powertrain control module, free of charge. The recall is expected to begin July 6, 2018. Owners may contact Chrysler customer service at 1-800-853-1403. Note: Owners are advised to stop using cruise control until the software update has been performed. In the event that cruise control cannot be disengaged while driving, owners should firmly and steadily apply the brakes and shift the transmission to neutral, placing the vehicle in park once it has stopped.
edit: it's definitely going to update the PCM.. https://static.nhtsa.gov/odi/rcl/2018/R ... 2-2370.pdf
Im not saying the pcm wont be updated, but that the pcm doesnt tend to control cruise control, so the fix is likely in a different module.
There is no way for us to support the new pcm cal, so the only option to retune after they perform the update s to let the tool put you back on the previously supported pcm cal.
Wan2fly
Post by Wan2fly »
I too had a recall to flash the stock pcm for a number of issues.
How will this be incorporated to a update to the Diablo pcm?
They obviously are required for many safety reason.
Yes the recalls are for the pcm as a whole. So this then leads me to the required updates needed on me pcm shipped as a diablo package
Await your reply for a fix
Wan2fly wrote:I too had a recall to flash the stock pcm for a number of issues.
There is no means at this time of supporting the most current files they applied to your PCM.
That means the only way to tune the vehicle is to allow the device to load a calibration to put it back on a supported cal.
Personally, without having reviewed the actual files, I (and others I work with here) are pretty sure the cruise fix that everyone is worried about is in the BCM, so the new PCM cal seems to be more of a way to make sure everyone is on a new, encrypted calibration. Double edged sword that they are taking full advantage of.
FWIW, we have a literal fleet of affected vehicles, and no plans to apply these "fixes"....
Quick shot I took earlier in the bay.
From front to back....
18 Challenger R/T
17 Charger Scat Pack
16 Wrangler
06 300C
And hiding behind the 300...is the shy 16 Chally Hellcat.
We also have a 14 Ram 1500, 18 Wrangler JL, and theres an 18 Charger Scat Pack roaming around somewhere.
Wan2fly
Post by Wan2fly »
Thanks for the reply mike. Nice shot as well
I posting the mandatory updates done to the modules
Auto park functionality recall
18-u0-51-50, PCM18-U0-51-51, TCM 18-U0-51-52, RFH 18-u0-51-53 IPC
reprogram powertrain control module
18-U6-10-81
Look forward to your feed back and thoughts
near as we can tell the pcm update is just a way for them to load an encrypted file to your pcm to keep you from being able to tune it.
Booms
Post by Booms »
I got the Cruise recall done on My 2015 Express, and the tech told me it had absolutely nothing to do with My PCM/tune.
On another note, thank goodness for my service writer and technician. They don't care about my tune...or any other mod on my truck. 8)
pitbull2424
Post by pitbull2424 »
So in a recall situation are we advised not to return to stock on new pcm and let dealer do there thing?
Per Mike's response "load an encrypted file to your pcm to keep you from being able to tune it", we will not be able to install last tune again?
Thanks.
pitbull2424 wrote:So in a recall situation are we advised not to return to stock on new pcm and let dealer do there thing?
Thanks.
if you are using your only pcm, return the vehicle to stock and let them do their thing.
If you still have the stock pcm, simply install it, let the dealer do their thing, then reinstall mod pcm when you are done.
Nightshade
mikel wrote:Im not saying the pcm wont be updated, but that the pcm doesn't tend to control cruise control, so the fix is likely in a different module.
What I was told is: "Cruise one is a pcm flash. because if the cruise switch is pressed at the time of a CAN bus failure it could cause it to keep accelerating, and not see a brake sense"
I haven't taken mine in for the update yet. I will just return to stock, take it in,, hope I can still tune once it's done. Is there a risk that the dealership updating the PCM code will remove the tunability of the Diablosport unlocked PCM? IE will we have to have them unlocked again? or is the 'unlock' part more or less a permanent thing?
No, they just update it, the pcm is still unlocked.
