I2 problems 03 8.1l
I2 problems 03 8.1l
Im trying to use the scan tool option, says failure occurred and then failure reported. I try to put in my custom tune and the handheld freezes when I press advance tune... all updates have been done, very upsetting to spend so much on a device that has so many issues.
Re: I2 problems 03 8.1l
Anything aftermarket installed in the vehicle? i.e did not come from the factory?
You need to make sure anything aftermarket is disconnected/pull the fuse for - anything like aftermarket stereo, subs, amps, nav, alarm, remote start, seat heaters, trailer brake/light setup, etc.. anything like that, their wiring harnesses need to be disconnected/pull the fuses for it before you try to tune anything...
also make sure everything is turned off inside the truck.. lights, radio, heat/fan/blower, do not operate power windows, put your parking brake on, etc...
It worked fine last week, now it wont work. I've done everything you suggested.
So when I try to use the scan tool, I get "an unexpected failure has occured" then it creates a failure log. On the tuning side, when I hit advance tune it just freezes.
can you please post the current info.xml file from the i2 drive?Badgasr wrote:So when I try to use the scan tool, I get "an unexpected failure has occured" then it creates a failure log. On the tuning side, when I hit advance tune it just freezes.
the tool is married, do you have a tune loaded to the truck?
Didnt see confirmation, is there an aftermarket stereo in the vehicle?
Yes the Diablo tube is loaded. I want to put my custom tune back in and also read my CEL. Stock stereo.
please update it with ignition and try again and let me know if it works after the update.Badgasr wrote:Yes the Diablo tube is loaded. I want to put my custom tune back in and also read my CEL. Stock stereo.
I have, no better results.
please post the current info file from the device.
OK, can you post the backup from the tunes folder here so we can move forward and reset the device?
Will I lose my custom tunes?
