Firmware can not be replaced
Hi @ all,
I can't update my device.
No tuning ist possible.
Re: Firmware can not be replaced
load this to the intune drive then let it import it then run the update again.
- intune-1r03y.itf
- (1.82 MiB) Downloaded 618 times
Thx, the file is on. I'll try it tomorrow.mikel wrote:load this to the intune drive then let it import it then run the update again.
Hello mike,mikel wrote:load this to the intune drive then let it import it then run the update again.
currently I only can find these 2 files on the inTune.
Where ist the file you sent me? Is it hidden?
It still wants an update.
Tried to put the sent file on the device again. It tells me it currently cannot be replaced.
yeah, that file he sent you will not show up to where you can see it man... you import that file he gave you, into the intune.. once the intune has imported that file and is back at the main menu, then do like he said, and run the Updater again to update your intune.
Sorry guy's this is not working.06MonteSS wrote:yeah, that file he sent you will not show up to where you can see it man... you import that file he gave you, into the intune.. once the intune has imported that file and is back at the main menu, then do like he said, and run the Updater again to update your intune.
The device is ending in telling me always like post #1
and then "update failed".
What can I do?
And this came right now:
post the current info.xml file from the device please.
mikel wrote:post the current info.xml file from the device please.
the device is up to date at this point.
But why is it always asking for an update?mikel wrote:the device is up to date at this point.
its a bug in ignition, we are looking into it.
Any news?mikel wrote:its a bug in ignition, we are looking into it.
Otherwise would a reset of the device help?
i thought it was updated, what is it you still need assistance with exactly?
Yes it is updated, but in the car it still is asking for an update.mikel wrote:i thought it was updated, what is it you still need assistance with exactly?
did you run the updater again?RAM_Andy wrote:Yes it is updated, but in the car it still is asking for an update.mikel wrote:i thought it was updated, what is it you still need assistance with exactly?
if so please post the current info.xml file.
