modified tune car no start
saleen9973
I modified my tune on my 2005 gto today. it went through but all my warning lights stayed on the dash. I went to start the car and no go, no crank. tool says vehicle not supported, it says update. So i update and still no crank. I then pull battery and put back on, It starts. I go to data log and see that my PIDS are changed. I now have no fuel trims, i have stupid things like fuel level and some other stupid stuff. I go to add pid, add fuel trims fuel trim go to screen but stay at 1 they dont change. Does anyone know what is going on?
saleen9973
Re: modified tune car no start
So i hooked up my regular code scanner, and i can see my fuel trims. Then i hooked the DS to my laptop and i can also see the fuel trims just fine. So the update somehow screwed up me being able to see my fuel trims on the tool. What should i do?
we are working on a fix for the fuel trims currently.
saleen9973
Any word yet? Will there be a new update?
No, wasnt going to be a same day thing, they are indeed working on it and will have it fixed soon.
saleen9973
Hey it's been over a week. Any update yet
copy this to your i3 drive and let it import the file, then choose the restore default pid option and record a new log. If you could post that log here afterward that would be great.saleen9973 wrote:Hey it's been over a week. Any update yet
saleen9973
I hope this loaded. So you know it didnt change the PIDS they are still messed up.
OK, did you perform the restore default pid option as well?
Can you also post the current info file please?
saleen9973
Yes i did perform the restore default pid. I will get the current info file tomorrow.
