save this file to the i2 drive and let it import the file then you can tune your truck.
I2 2018 F150 5.0
Re: I2 2018 F150 5.0
Works great, thanks for your helpmikel wrote:save this file to the i2 drive and let it import the file then you can tune your truck.
Mikel, I am getting DTC P0500 "Vehicle Speed Sensor" Error with this tune. Please Help.
ok, did you make any adjustments to the tune when you loaded it?
Will you please post the info.xml file from the tool as well as the files from the tunes folder on the i2 drive so I can check it out?
[quote="mikel"]ok, did you make any adjustments to the tune when you loaded it?
No adjustments, the only thing the tune would allow me to change was axle and tires. Nothing else. Files attached.
OK, so, did you adjust the axle or tire setting?
The reason i ask is the code you describe sounds like one that may come up if that stuff is adjusted incorrectly.
Do you have stock gears in the truck?
Taller tires?
Taller tires?
mikel wrote:OK, so, did you adjust the axle or tire setting?
Taller tires?
"NO ADJUSTMENTS MADE to any parameters". Vehicle is STOCK except Roush Air Intake.
corrected database is here.
