06 Mustang GT
adelgado
06 Mustang GT
Post by adelgado »
Just installed the U7140 on my stang it is awesome, I installed the Air Raid tune, but I wanted to know what parameters I can change on the timing to give it a litle more go if I choose to go with 93 Octane gas? I have only Flowmaster mufflers, and an Air Raid cold air intake. Any help would be great, thanks...
christina
RE: 06 Mustang GT
Post by christina »
Unless stated otherwise, the tune is for 93 octane. If you use a 91 octane tune, you can go into Modify Tune/Modify Parameters/Spark Advance/Global Spark and add 2* if you wish to run 93 octane.
Christy High
lurker.
rtgendron47
Post by rtgendron47 »
Christy, does the airraid tune come with a 91 or 93 octane tune with it. I thought it was a 93 octane. Let me know. Thanks
Phil
Post by Phil »
rtgendron47, All CAI tunes are based off of 91 octane fuel. You can go into the Global spark table and add 2 degrees of timing so you can use 93 octane fuel for maximum performance.
Phil Jones
Diablosport Inc.
Tech Support
Please do not PM us for tech support, post up first!!!
rtgendron47
Phil, the venturi ring should be taken out also, correct? Thanks
christina
Post by christina »
Yep, the tunes are written with the venturi tube out.
Christy High
lurker.
twfolks
Re: 06 Mustang GT
Post by twfolks »
adelgado wrote:Just installed the U7140 on my stang it is awesome, I installed the Air Raid tune, but I wanted to know what parameters I can change on the timing to give it a litle more go if I choose to go with 93 Octane gas? I have only Flowmaster mufflers, and an Air Raid cold air intake. Any help would be great, thanks...
I have the same setup, you should beable to go into "OEM" tunes and select "Airaid Firm Shift" this is a 93 oct tune with this tune you will be grabbing rubber for sure in second and probable 3rd if you have anautomatic
Return to “Predator Ford Gas”
