I have the SLP7190 for my 05 GTO and when I try to read with DSLogRedux it says I did not make a WOT run. I know I did
. When I check the log file it shows AFR around 17 at WOT. It used to show around 12. I am thinking this may have happened after I updated to 8r07. I searched here but didn't see anything about this. LS1GTO had something and I saw that subtracting the difference from 14.75 AFR, which is my normal cruise AFR, would give me the correct WOT AFR.
Is this correct or is there something I need to do to fix this issue.
Alec
