warranty issues...
warranty issues...
Does installing the Predator on a 07 SRT Charger void any warranties associated with Dodge?
There have been several threads on this subject, some dealerships have no problems with folks using a tune, other though will take a hard stance on the warranty policies. But long story short, the majority of folks here will tell you to always go back to stock before you drop you car off for service. hope this helps.
- fordomatic69
RE: warranty issues...
Yes........... and No
When you use the predator the first time, you will back up your original PCM file first, then you will upload a tune to the car. If you need warantee work or service from a Dealer, especially anything that is electrical in nature, you should restore your factory tune and then take it to the dealer. It is likely that they would void your warantee if they knew you were using the predator. Depends on the Dealer and your relationship with them. Let's just say that the predator is NOT "New Car Warantee Approved"
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
