T2 not shutting down MDS
I have recently purchased the T2 for my 2013 charger pursuit & have yet to get msd to shut down. This occurs no matter the tune I load. If I try to change it in the switches controls the tuner goes to the please wait screen & freezes with 0%. I have rest & reloaded twice with no change.
Re: T2 not shutting down MDS
can you please post the info.xml file from the device as well as the last tune written from the tunes folder so I can turn it off for you?
tech@diablosport.com
tune was diablo/93 octane
Im looking for the actual tune file from the tunes folder on the i3 drive please.
is this what you are looking for?
save this to the T2 drive and let the device import it then load the pcm custom tune and it will be off.
Thanks for the help and work!
Im having the same issue in my 2012 SRT 300
please post the last tune written from the device so i can check it out.1EVL300 wrote:Im having the same issue in my 2012 SRT 300
Could i get another MDS shut down? thanks in advance
here you go.71smoker wrote:Could i get another MDS shut down? thanks in advance
