Recalls and diablo PCMs
TonyMM
Re: Recalls and diablo PCMs
Post by TonyMM »
Hi,
My truck (2016 RAM1500 5.7l) just went for some recalls (U61 Cruise Control, U07 Auto Park and U53 Occupant restraint controls module)at the dealership.
Prior to the recalls at the dealerships I loaded the original backup prior into the Diablo unlocked PCM.
The Diablo Trinity says that my custom tune (68......AF) is no longer supported and that calibration ID (68...AI) is not supported.
Furthermore it ask to downgrade to "68...AF".
What should I do now? Should I really downgrade??
I want to keep the recalls of RAM in my truck but I want to use the Diablo tunes and the custom tunes as well...
Help.......
TonyMM
Post by TonyMM »
its putting you back on the same cal you were on previously, which is the one we support, let it do its thing.
You'll also be able to reuse the custom tune once the cal is backdated.
TonyMM
Post by TonyMM »
OK. DONE!
BUT
The option for the Diablosport Transmission Performance Tune disappeared however :shock:
I am using a custom tune and I can modify the parameters but the option to install the Perf Trans Tune is not shown anymore.
-> How can I install the Diablosport Transmission Performance Tune together with my custom tune?
it doesnt ask you to update the tcm?
TonyMM
Post by TonyMM »
No :?
I select Performance, then "custom tunes", then I select the custom tune that I have transferred to the Diablo Trinity (hemifever PCM tune). I have then the possibility to change some parameters (MDS etc..) and then it saves the PCM and write the tune on the PCM and that's it.
2016 RAM 1500 5.7l
dcx_gas_15
V.1r23e
please put it back to stock then give us a call and we can try forcing a tcm calibration update.
TonyMM
Post by TonyMM »
OK!
I just need to get the Diablo Trinity back to stock and to have the Trinity attached with the PC via USB them right?
Or do I need anything else ?
no, vehicle back to stock then call with device connected to the vehicle.
TonyMM
Post by TonyMM »
SOLVED ! THANKS!
Called the help hotline (5 min waiting time and 5 minutes on the phone), performed the forced trans calibration update and now everything is working again!
THANKS!
awesome.
