I have the I2 for the Dodge Ram and decided to update it before use. I installed the updated version of the Ignition updater to Update Agent and began the update process. Now it is on the installing update screen, which it has been on for over 2 hours. I've unplugged it, tried it on another computer and plugged it into the truck and the only screen I get is "Installing Update".
I also purchased an additional license for this device which does not seem to come up.
Attached is the info file.
<?xml version="1.0"?>
-<tool_info platform="I2">
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="14U7Z5KOC0"/>
-<applications count="5">
<application rev="2r03w" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01r" name="gui"/>
<application rev="2r01m" name="installer"/>
<application rev="2r01d" name="logger"/>
</applications>
-<databases gui="2r00" vin="2r01i" dtc="2r01a" dbnames="2r00">
<database pid="2r01e" tune="2r02m" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
-<system rev="1r01a" config="1r01e">
<kernel version="#7 Sat Sep 19 01:29:28 EDT 2015" release="3.17.2-diablo2"/>
<option name="Wifi" enabled="false"/>
</system>
<licenses tuned="0" available="1"/>
<reg reg="M23SLSl7xVRg/26IlNFuJtvZOafCbsGlghLO2gQ+bRvl1fUK5y87apgnxJI9kWcceY6kqY6/UXJVrB7IBVxiRve/lpP+KjICp71eKSDObNUQazhewrdHsYKz9LFe/5HhJIh8+XnMDctGLJL9Ml48o+ucvp7GLkAZCFZGGtk4CpQsdgy3bjOjZ4MA0RL5CLBx8eWU2GvPtDImCf6FkSJtEqOhfPnms1HyGSB/ZQxQTUu4Ig3NNqDQZOa7BHobE8xG9doFaUBMjxlhvxbP725MGjjUX2hRD8Un42cnjRqi0Aw21ifVN+Qad7FoVHVpQ3RmbLeAM/ydSW7R8HhLon4Ft+QCczuqwGO4tHnQ+qcS/qdCcdHBpcuGGq8LKorrzzpnXwV9rIt1JvB8pDmsnOf44790kAn85HfwmX+zvChJifkeTuJXW/6Syj8ePmmVHAAbfcR+uC9lIe626h7/fLDolAGMn5XRQGF+YOqKG7KQQq1HLZnl744="/>
</tool_info>
I2 stuck on "installing update" screen
Re: I2 stuck on "installing update" screen
Problem solved, I got rid of the I2 tuner. I can't believe new out of the box this had an issue in this day and age of technology.
We discontinued the i2 about 2 years ago, can you tell me where you got one new in the box?
