Air fuel ratio
dodge59
Air fuel ratio
Post by dodge59 »
Hello does the A/F ratio show up on the predator so i can fit a new throttle body which if it works properly should lean out the motor
and can i adjust to suit
Regards Mike
my other car
Re: Air fuel ratio
Well, you didn't say what vehicle....thats gonna be key.
dodge59
Re: Air fuel ratio
Post by dodge59 »
Sorry Mike
2008 Chrysler 300c 5.7 93 oct cai tune catch can magnaflow exhaust cat back brisk plugs
Thanks mike
my other car
Re: Air fuel ratio
No, you need to add a wideband O2 sensor to see AFR on that vehicle. A throttle body is not going to lean you out. Bigger concern is the potential driveability issues that can come with an aftermarket or ported throttle body that will require custom tuning to fix.
dodge59
Re: Air fuel ratio
Post by dodge59 »
In that case Mike i will leave well enough alone
THANKS FOR YOUR HELP
Regards Mike
my other car
