Mds not turning off also tuner freezing
Has anyone else had a problem with the Mds not turning off on a 2012 Dodge Charger R/T. Every time I turn the mds off and push save the Trinity 2 freezes at zero. I have to unplug the turner to get it to restart. This issue started after last update before that everything was fine.
Re: Mds not turning off also tuner freezing
post the last tune written from the tunes folder and I will disable it for you for now.
Pittbullspeed
I'm having the same problem. I just receive a replacement because my was not working like it shut so I open the new one, update it and went to my 2012 Grand Cherokee SRT8 couldn't disable and still can't disable the MDS switch and I'm going crazy of the change of sound when ECO appears. Everything else is working great except that little detail. If some one can help me I will be appreciated. My email is [email protected]
please post the last tune written from the tunes folder on the T2 drive please.Pittbullspeed wrote:I'm having the same problem. I just receive a replacement because my was not working like it shut so I open the new one, update it and went to my 2012 Grand Cherokee SRT8 couldn't disable and still can't disable the MDS switch and I'm going crazy of the change of sound when ECO appears. Everything else is working great except that little detail. If some one can help me I will be appreciated. My email is [email protected]
Pittbullspeed
Mikel, the attachment is the last tune written on the T2
what I am asking for is the file in the tunes folder on the T2 drive called lasttunewritten.
Pittbullspeed
I made the file for Amber this morning, she will sent it to you soon, or its attached here.
Pittbullspeed
Tiredofthis
I am unable to turn off the MDS on my '15 Ram 1500. If I turn off MDS and install the tune, then I go back to tuning, it shows a change was made to MDS but shows that it is still on.
I have attached a copy of the last tune that I put on the truck.
If you set it to off, then load the tune, its off
it is OFF in the tune you attached.
It defaults to ON in the menu but thats not showing you what its set to.
