I appreciate that suggestion, but I think I'll just stick with what you guys have put out in the canned tunes. I'll patiently wait for a more permanent fix from DiabloSport.mikel wrote:If you had a 93 tune you liked, you can just pull 2* of timing for use with 91 octane...
I wish I was close to you - I'd let you have my car for a week. These tunes do not downshift properly, at all - at least on the 2006 5.7s. I don't know about the other years - I haven't been keeping score. There is no reason for someone to be cruising in "D" at 50MPH, decide to get on it, downshift using autostick, and end up in 4th gear. The proper gear it should put you in is 2nd, so it's not even close. I'm not the only one with this issue, in fact I bet that it's across the board, at least on the '06 5.7s.
I know you guys are busy and have your direction re: new model vehicles, special projects, etc., etc., but please don't forget us. I would be competely satisfied if you just make a concerted effort in the near future to fix this issue, rather than just blow by the topic. Thanks in advance.
