TCM reset key cycle procedure U7135
I am still getting used to the U7135, so far I have installed a 91 CAI tune and I am ecstatic with the results so far. Today I decided to do a TCM reset. In the manual, it is saying nothing has to be flashed, just a series of key cycling to reset, but as I was going through the steps, Quick adjust, transmission, tcm adjust, no where did it tell me to cycle the key...did I miss a procedure somewhere?
RE: TCM reset key cycle procedure U7135
It didn't tell you to turn the key off/on? Thats cycling.
under QA if you selest one of the functions, say autostick disable and answer yes, it will ask you to turn the key off/on.,
I will try again tonite, but I tried it twice last night, maybe I missed something,
but I did manage to get to the TCM reset feature, after performing the reset it didn't really say anything after that as to a successful reset or to turn the key off and unplug or again, cycle the key, I did feel that it wasn't thorough as it was with a tune, even though it is not the same procedure...I will try again.
PS: maybe just send me step by step and I will follow your procedure.
- fordomatic69
1. Open the hood
2. Pull fuse 11 (same thing as TCM reset).
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
- fordomatic69
sorry.. dry sense of humour here..... actually fuse 11 pull does more than just restting TCM adaptation according to what I've heard. The Predator does a fine job as well but just resets the TCM only.
Fordomatic Says:
- fordomatic69
I pulled the fuse last night. No issues at all. Got rid of my MDS surge for now with the 91CAI tune.
Fordomatic Says:
