U7194 , Release 8r05, connected to a E38 GM ECU.
Live data log will only record 90 seconds of data before "log full" message is displayed. It does not matter how many PID's are selected, the log time does not change.
What am I doing wrong?
U7194 , Release 8r05, Log file problem
RE: U7194 , Release 8r05, Log file problem
What revision is that Predator on?
it's right in the first line, isn't it??... Release 8r05
I know, it's been a long day...
Any news on this issue?
same problem
I'm having the exact same problem. Mine has the latest update in it.(8r05)
OK it's been a week and a half since I brought this issue to the attention of Diablo through the forum and e-mails with log files attached. Do you have a resolution or work around. Do I need to ship you a Z06 E38 ECU to use for technical trouble shooting. 90 seconds of log data is useless. Do I need to go back to HP Tuners VCM scanner and return the Predator U7194. I need a realistic answer to the problem now!
e-mail: [email protected]
We just bench tested this issue today and confirmed that the logs are too short.
We are looking into what needs to be done to correct this problem.
I can only ask for your patience in this matter while we resolve the issue.
