2006 mango daytona intune i1000
daytonadale
Post by daytonadale »
Helloo my car is a 2006 dodge daytona charger and i have a problem with my device. Sometimes it read no ecu found and now that the connection problem has stopped for the most part... it says vehichle not supported. I tried updating which didnt go correctly.. The only reason i brought the i1000 back out the box is beause my car started stalling and idling low which I recently found to be most likely a tank problem ima see if I cant get warrantied while the car is going in for the airbag recall..... So i call myself release the vehice before tryin to update it... the progam on my intune is intuner updater 2r01f which reads (( my tool needs the file /var/www/private/buildfiles/i1000_diablo_gm_tune_1r02u.itf but
was unable to locate this file information available )). the car was last tuned a while ago cause i dont drive it much... I even tryed the "registry reset" which I don't exactly is but after the key shows up i dont know what to type in next . Can you help me, please ? Car didn't stall as much before I detuned it.. msd makes it stall fast even while warming up.
seria l number - JNNNIDA-6
application ir04i
missing dcx tune db:
Thank you...
Re: 2006 mango daytona intune i1000
it needs to be updated, download the update agent software from our site then use that to update it and it should be ok.
daytonadale
I've tried. Can u post the correct link? I'll highly appreciate that
daytonadale
Even after I download it where do i drag it to? Tunes folder?
Im not sure what you are asking.
The update agent software will download the files and put them on the device automatically, you dont have to drag anything anywhere.
daytonadale
Ok finna try now
daytonadale
Think my question when i click download do I run it to My computer or click save as application on the CD drive (F) or intune (H) ? I'm lost now lol never had to update it
daytonadale
Here's what I end up getting
ok, i see the i2 updater there, you shouldn't be using that.
Download the update agent software here:
http://fusionupdate.com/ignition/powert ... taller.exe
Just click the link and let it download then it will ask if you want to run it, choose yes. It will walk you through the installer, just click next, next, then finish.
From there it will launch the updater and ut an icon on your desktop where you can access it in the future if needed.
daytonadale
Are u thru helping me? I can't figure it out...
You need to install that Updater Agent software on your PC bud... then you need to use/run that Updater Agent program on your PC to update your intune.
daytonadale wrote:Are u thru helping me? I can't figure it out...
I posted step by step instructions on how to resolve this, if you need further assistance please feel free to give us a call from the PC and we'll get you going.
