adjusting the PE on a 02 camaro...U7198
boola1341
Post by boola1341 »
At high rpm WOT my AFR is around 11.80-12.20. I know that's running rich so how much PE do i subtract. And at low rpm it gets up to 13.5....how much PE do i add to riching it up????
boola1341
RE: adjusting the PE on a 02 camaro...U7198
Post by boola1341 »
Also i've added long tube headers if that matters.
2002 A4 LS1 Camaro
Pacesetter Long tube with ory
Flowmaster Catback
3.73 gears with a Auburn differential
Slp air lid and msd wires with ngk tr55 plugs
Best time is 12.89@109 with a 2.0 60' on BFG Kdws street tires
boola1341
Post by boola1341 »
Anyone????
2002 A4 LS1 Camaro
Flowmaster Catback
rletzgus
Post by rletzgus »
how are you monitoring AFR on the U7198. You must be cheating. I have U7198 and can't monitor AFR. Waaahh! I want my AFR too. I would guess just start subtracting 1% each time till you hit the mark you want.
2001 GMC Sierra
4.8L
K&N FIPK Cold Induction
Headers
2.5" duals with Delta 50 Flowmaster
B&M tow shift kit on 4L60E
Predator U1798 ver 9r15
MSD Ignition MSC Multispark coils
boola1341
Post by boola1341 »
i'm using the innovate LM-1 to monitor my AFR.
2002 A4 LS1 Camaro
Flowmaster Catback
rletzgus
Post by rletzgus »
Oh. Is this a wideband O2 sensor. Who makes it and where do you get it? Thanks.
2001 GMC Sierra
4.8L
Headers
boola1341
Post by boola1341 »
innovate motorsports makes it and the website is www.tuneyourengine.com. But i purchased it off ebay from a registered dealer.
2002 A4 LS1 Camaro
Flowmaster Catback
Return to “Predator GM Gas”
