Diablotunes stalling my 11 Charger R/t
Discuss Predator 2 for Chrysler vehicles
marcusrt32
Post by marcusrt32 »
Ok so i got one of the predator 2 tuners. i tried updating it plenty of times, but if i install either the 91 or 93 tune . my car stalls out about 30 seconds after i start it or whenever the rps die down. once i install the stock tune it runs fine been running 93 quality gas only. Also i feel as if some options may be missing the SRT pages dont work on my year i believe . there is no modify stock tune . i cant disable mds , rev limiter, top speed etc . ANY IDEAS PLEASE?? S/N: 201046532
Re: Diablotunes stalling my 11 Charger R/t
Are there any trouble codes when the car stalls?
Are you making any adjustments to the tune when you load it?
marcusrt32
there are no codes . i tried the tune with and without adjusting things multiple times it does the same
did one of our techs contact you about swapping you into an i3 device?
marcusrt32
yes i talked ti them . thanks for the help !
lhefe
Post by lhefe »
This sounds like the same exact issue I am having.
I purchased a Predator P2 for my 2011 Charger R/T AWD 5.7l
Hooked up the Predator, installed the 91tune and selected several custom options.
About 30 seconds after starting the engine it stalled. Vehicle stays powered on and in run mode.
P2 shows recovery mode and flashes back to stock config.
Drove down the street in stock config, no issues.
Try to install 91tune again, this time I didn't customize at all.
After starting, the engine idles very low and stalled in less than a minute.
Recovery mode shows up and flash back to stock.
Drove the past couple days without an issue.
I submitted a support request through the main page of the website but haven't heard anything.
Thanks for your time!
marcusrt32
@ihefe they said they have problems with the p2 for our model 11-14 chargers/challengers. i talked to them they are sending me the i3 thank god in exhanxe for the p2
lhefe
Post by lhefe »
Awesome! Guess I gotta call em and get mine swapped out as well.
I couldn't find much info online about 2011 Chargers with the P2.
Thanks!
Return to “Predator 2 for Chrysler/Dodge/Jeep/Ram”
