i1000 keeps freezing
fiona12
Post by fiona12 »
hello i need a little help im trying to untune my 07 gmc yukon but once i turn the key to on position it freezes
Re: i1000 keeps freezing
Anything aftermarket installed in the vehicle? i.e did not come from the factory?
You need to make sure anything aftermarket is disconnected/pull the fuse for - anything like aftermarket stereo, subs, amps, nav, alarm, remote start, seat heaters, trailer brake/light setup, etc.. anything like that, their wiring harnesses need to be disconnected/pull the fuses for it before you try to tune anything...
also make sure everything is turned off inside the truck.. lights, radio, heat/fan/blower, do not operate power windows, put your parking brake on, etc...
