I2 Says vehicle not supported but doesn't update
scrapmycar
Re: I2 Says vehicle not supported but doesn't update
I have an I2 that I purchased another license for to use. Now that the pcm is installed it says vehicle not supported. I've tried to update it and it
please attach the info.xml file from the i2 drive.
I am having the same issue. I have a 2014 Ram 1500 and when I plug it into the OBD II port i get the vehicle not supported message too. Same with the updates. I run the updates but its like it is updating but not updating. I attached the info file. I hope you can help me out. Thank you!
- info.xml
- (2.8 KiB) Downloaded 531 times
the device is not asking for an update, seems to be a connectivity issue where its not communicating with the vehicle?
Well then what should I try? I'm at a loss here. But it's not updating because when I update it says it updates but when I disconnect it and then connect it again it still keeps trying to update.
give us a call from the vehicle and we'll check it out.
Ok cool I'll try to give you a call later today
my 2014 charger is also saying it is not supported, I did the update but it still says the car is not supported and it still show the cars vin in the hand held
- info.pdf
- (28.24 KiB) Downloaded 583 times
migue_alex74
I completed the update on a PC, But I get the same error message, tried to call customer service but it is after hours.
Attached my files
Attached my files
- PCM_68253702AC_LastTuneWritten.drg
- (123.58 KiB) Downloaded 450 times
- info.xml
- (2.16 KiB) Downloaded 493 times
