Can anyone elaborate on timing advance briefly? Is 40 deg. to high at 65 mph? What are safe timing ranges for optimal performance ?
Thanks!
Spark Advance???
sickREDsierra
RE: Spark Advance???
45 degrees would be your cruise timing, which is not that super important, and will fluctuate....
we like to focus on your WOT (wide open throttle) timing.... you should see any where from 20-26 degrees at WOT, depending upon how much advance you are running, what supporting mods you have, etc.
monitor your real time data on your vehicle while driving, and watch the spark readaout from a cruise....then punch it... you will see it drop substantially....... some cars run around 23-24* at WOT stock, and most trucks are around 20* stock at WOT
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
mooshnicka
thanks for the confirmation... I will have to see what the spark readout is at WOT...
sickREDsierra
no problem bud.
I've got my LTFT's dialed in and seem to be working really well. I played with Spark advance last night and advanced it 2. It felt like a negitive effect on performance. Do I want to advance or retard and was 2 enough or should I have gone more. But I assure you it was worse performance than before. I put it back to the normal setting, and performance came back. I made all 3 settings +2 to see what effects it would have. Also monitored the knock, and was NOT getting any.
Any ideas?
Steven
Any ideas?
Steven
2007 GMC Sierra SLT Vmax. 4.10 gears, Bedrug, Boss MT100 20x8.5 wheels/Kumho STX tires, Extang Bed cover, Light of fire, Denali Grill, GM Performance Intake and DiabloSport
sickREDsierra
Re: RE: Spark Advance???
Stevens07 wrote:I've got my LTFT's dialed in and seem to be working really well. I played with Spark advance last night and advanced it 2. It felt like a negitive effect on performance. Do I want to advance or retard and was 2 enough or should I have gone more. But I assure you it was worse performance than before. I put it back to the normal setting, and performance came back. I made all 3 settings +2 to see what effects it would have. Also monitored the knock, and was NOT getting any.
Any ideas?
Steven
if you went + 2%, then you didnt advance very much at all... your timing will always reach a point where it isnt beneficial to add , it just cant make any more power..
what is your total timing at WOT, just curious?
i run about 26* in mine, any more just didnt amount to more power... it reached that happy point at 26*.
RE: Re: RE: Spark Advance???
I'll have to check, I don't know....
Btw, I killed an SS camero yesterday on a two lane country road. I had to keep letting off the gas
i don't think that camaro was running you!!!
2002 A4 LS1 Camaro
Pacesetter Long tube with ory
Flowmaster Catback
3.73 gears with a Auburn differential
Slp air lid and msd wires with ngk tr55 plugs
Best time is 12.89@109 with a 2.0 60' on BFG Kdws street tires
Flowmaster Catback
what's your 1/4 mile time?
2002 A4 LS1 Camaro
Flowmaster Catback
Flowmaster Catback
