Analog wiring with Diablo inTune and Diablo Analog Pigtail
Alright fellas, I finally got a pigtail, i ordered the diablosport T1015 pigtail and it fits and has plenty of length, but it didn’t come with anything stating which wire is which lol anyone know what color wire I tap to the 5V, power, and ground?
Re: Analog wiring with Diablo inTune and Diablo Analog Pigta
there are 2 positives and one shared ground. Use one of the 2 + and the - to set it up.
Well what i mean is which wire on the pigtail do I use? I have a white, red, and one wire with no insulation (bare wire) which is ground/power/powermikel wrote:there are 2 positives and one shared ground. Use one of the 2 + and the - to set it up.
right, the 2 insulated wires are +1 and +2. Use either one. The uninsulated one is the ground.
The reason that you have more wires than you need is that the pigtail is 2 channel and you only need one for the 02 sensor. On another post I was informed that the tip is "channel one" for the intune. First side ring is channel two, and base of jack is ground. Hope that helps. Btw, I am still trying to get my PLX SM-AFR to work. I will post my question in a separate thread.
