Cannot reset dtc
Cannot reset dtc
I have a 05 Duramax / Allison when using the Predator 100 hp tune,I went into limp mode,and got check engine light, I believe I lost 1st and 4th gears. I went back to stock tune, truck runs fine now,but cannot erase p0700 code and reset light.
Cannot reset dtc
The truck has cleared and reset check engine light, AOK
RE: Cannot reset dtc
You likely overpowered the clutches in the tranny.
The P0700 will only clear itself after a few key cycles.
