Issue with i2 and Innovate LC-2
rking620
Post by rking620 »
I am having an issue with passing data through to Dataviewer from an Innovate LC-2. I have wired the 0v-5v analog output to the Trinity T1015 analog cable's red wire. Not knowing which wire was which input, I programmed the following into my intune:
Channel 1
Units: %
Lower bound: 7.35
Upper bound: 22.39
Channel 2
Units: %
Lower bound: 7.35
Upper bound: 22.39
Once I was connected to Dataviewer, the AFR1/2 gauges showed 7.350 as the reading, with 7.350/7.350 % as the scale. They do not change. I have checked with a voltmeter, and I am seeing the correct range of volts on the ring, and 0.0 on the tip (expected).
I can connect to the Innovate LC-2 with its software and get AFR values, however, this does me no good if I can't log alongside what the rest of the engine is doing.
Edit: I've set the LC-2 to output 5v during warmup. With my voltmeter I am getting a reading of 5.03 during the warmup period. The LC-2 is working properly, the analog cable is wired correctly, the i2 or Dataviewer is not reading or interpreting this data correctly.
Re: Issue with i2 and Innovate LC-2
Can you try logging directly to the device and see if it records it there?
rking620
Post by rking620 »
I can't select those PIDs to log on the i2. Will they log automatically even though I haven't added them to the list? I will give it a shot this afternoon. Thanks!
once configured they log automatically.
sbenja2008
Post by sbenja2008 »
I'm having the same issues with my i3 and an autometer gauge there has got to be a fix for this.
