Hi Mike,
i opened the attached tune (which my tuner set to a 7000 rpm rev limit) but the i2 displays 29561 rpm, any ideas?
xml and tune attached
thank you!
srt4 can't changing rev limit
Re: srt4 can't changing rev limit
if you move it does it display correct values?
yes i can change the values (changed to 7000) and and it loaded just fine
but
my car wouldn't start , and i couldn't load any other tunes or restore (even disconnected the battery for 10 minutes)
tuesday called diablo tech support for the code to force restore.. (up and running again) -- tech support is the best!!
but
load the canned tune with no changes then post the last tune written here please.
Hi Mike
attached is the last tune written
should rev to 7k here.fixit wrote:Hi Mike
Mike
Thank you, works perfectly..
Since this is the 2nd problem i've had with custom tunes that you were able to fix..
Is there any trick i should be doing or my tuner to prevent this in the future..
Thanks again!!
Thanks again!!
mikel wrote:should rev to 7k here.fixit wrote:Hi Mike
