srt4 can't changing rev limit
fixit
Post by fixit »
Hi Mike,
i opened the attached tune (which my tuner set to a 7000 rpm rev limit) but the i2 displays 29561 rpm, any ideas?
xml and tune attached
thank you!
Re: srt4 can't changing rev limit
if you move it does it display correct values?
fixit
Post by fixit »
yes i can change the values (changed to 7000) and and it loaded just fine
but
my car wouldn't start , and i couldn't load any other tunes or restore (even disconnected the battery for 10 minutes)
tuesday called diablo tech support for the code to force restore.. (up and running again) -- tech support is the best!!
load the canned tune with no changes then post the last tune written here please.
fixit
Post by fixit »
Hi Mike
attached is the last tune written
fixit wrote:Hi Mike
should rev to 7k here.
fixit
Post by fixit »
Mike
Thank you, works perfectly..
Since this is the 2nd problem i've had with custom tunes that you were able to fix..
Is there any trick i should be doing or my tuner to prevent this in the future..
Thanks again!!
mikel wrote:
fixit wrote:Hi Mike
