Questions about DCX Tuner and tunes
Activate
Post by Activate »
Hello,
I have bought my friends Intune I-1000 with HemiFever ._87-Octane-hf.drg and ._91-Octane-hf.drg.
There are no more tunes in the Tune directory on the tuner is that right?
This is the info.xml, there is still his vin number in it. must it be changed to my vin to use it?
Or must I register it again on my own name?
Thanks for the answers,
Greetings Erik.
<tool_info>
<main full_version='InTune-1r04j 03/14/2016 10:51:37 AM' sw_rev='1r04j' svn='9115'/>
<registration sn='JNQEQ49-6' status='1'/>
<cal_id PCM='68153810AD' CM1='68234060AA'/>
<restore id='0' vin='1C6RR7MT0ES214029' bc='24'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01g'/>
<db mfr='DCX' tune='1r01v' pid='1r01b'/>
<db mfr='FORD' pid='1r01b'/>
<db mfr='GM' pid='1r01a'/>
<license avail='1' tuned='0'/>
<updates count='5'/>
<oem tool_oem='DIABLODCX'/>
<reg reg='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'/>
</tool_info>
Re: Questions about DCX Tuner and tunes
its good to go on most 11-14 dcx applications, but those custom tunes were specific to his truck and will not show up unless plugged into that vehicle.
Activate
Post by Activate »
Thanks for the answer,
My truck is exactly the same (only the VIN is different) and want to use the tune.
How must I do that?
Thanks and greetings,
Erik.
You cant, you'll need to purchase a new custom tune for your truck or use the preloaded tunes.
