Write failed
tracyherzog74
Write failed
Post by tracyherzog74 »
When I try to tune, it goes through all the shut offs and Ons,backs up stock file then goes to write tune and says write failed and says intune is in recovery mode. I just had 2012 mustang gt put back to stock settings from dealership. What do I have to do to get this to write a tune on my car?
Re: Write failed
please call us to have it reset before you do anything else with it.
tracyherzog74
Re: Write failed
Well, I tried again and it wrote the 93 cai tune to the car, but it won’t write the jlt cai tune. So I got it to tune the one. What should I do?
tracyherzog74
Re: Write failed
Mike, should I flash back to stock then call u with the tuner hooked up and booted to see why it will not write the jlt cai tune or leave it since it wrote the 93 cai intake tune?
Re: Write failed
Load the standard tune for the octane you want then post the last tune written here and I'll try a custom JLT tune.
tracyherzog74
Re: Write failed
mike, this last tune written is the only thing i could find on the tuner, that and my stock file. i cannot find the standard tune for the octane i want. this is the 93 octane cai tune, the jlt cai 93 tune would not load. here is the info also.
info.xml
(486 Bytes) Downloaded 311 times
PCM_FPDN18A_LastTuneWritten.frg
(590.09 KiB) Downloaded 273 times
tracyherzog74
Re: Write failed
mike, heres the last tune, 93 oct cai file. i cannot find any other file.
(590.09 KiB) Downloaded 308 times
Re: Write failed
Load this to the device then to the vehicle.
PCM_FPDN18A_JLT.frg
(547.23 KiB) Downloaded 311 times
tracyherzog74
Re: Write failed
ok mike, got a problem, loaded tune into my car and now it wont start. i go to restore to stock and it says no ecu found. what do we do now?
Re: Write failed
Please give us a call asap with the tool powered up in the car.
