i3 for Hummer H3....whrre's the transmission adjustments??
Re: i3 for Hummer H3....whrre's the transmission adjustments
I have a new laptop on order. Should be able to provide the file in a few days
2009 Hummer H3T
1970 Dodge Challenger, 440, 4sp
Okay, new computer and the file is attached. Please take a look and let me know what you find.
Thanks!
Thanks!
2009 Hummer H3T
well, unfortunately none of the TCM cals changed, so either they didn't update it or there were no updates to apply, but either way, the TCM was not actually 'flashed' as it wont allow you to just reload whats already there.
So if the TCM was up to date, is there a ything the dealer could have done? Are you saying they couldn't overwrite with the same data as a reflash?
I was told it was reflashed with the most current software rev.
I'm asking mostly because I'm wondering if I need to confront them about charging me for service not performed.
Thanks!
Thanks!
2009 Hummer H3T
It is not easy to get their systemto reload whats already there.
it just doesnt work that way.
If there is a new file, it loads it no problem, if it sees the current file is the same as whats in the module already, it doesn't do anything.
None of the TCM cals changed from your old info file to the new, so they didnt do anything to the TCM.
Well, after wasting all this time and money, I tried a Banks programmer to see if it encountered the same issue of not being able to write to the TCM. No problem at all! It works great.
This Diablo unit is obviously defective.
Unit returned. Keeping the Banks.
2009 Hummer H3T
Glad to hear you got a working solution, sorry it didn't work out on our end.
