Hello, I have a 2006 dodge magnum r/t with a mild build and a custom tune and have issues getting the readiness states of the Catalyst and O2 sensor. I am quite certain that I can't get a hold of my tuner. Can someone tell if the rear o2 sensors has been disabled? I had recently reset it due to a transmission code. I could swear but am not sure if it ever fully readied. I'll upload the tune if in case that is possible. What would it take to get it enabled?
2006 Dodge Magnum r/t rwd Inertia Motorsports Big Valve Heads, Spartan Plus Cams, SRT8 Headers, Mids and Radiator, SRT8 Magnaflow clone catback are some of the mods.
Can someone tell me if my tune has the rear o2 disabled?
Re: Can someone tell me if my tune has the rear o2 disabled?
Nothing disabled here that should affect the rear O2s at all.
Okay, so I was correct that it was ready at one point. Thanks a million...you don't know how much of a relief that was for someone like myself. I tend to always expect the absolutely worse because it is usually true.
Oddly I had an evap code in the past but I checked my tank and all was well. EVAP shows ready too but in the Torque data logger there is one thing that says Not Okay. Still no code and it still says that evap is good.
