lose all acceleration if going up a hill
Would data logging help out in finding the problem with my 300 SRT 2013, at around 60K and 1500 revs I lose all acceleration if going up a hill .I can press the pedal to the floor and nothing happens until suddenly it kicks in and takes off . Anyone having the same problem or have a fix?
Re: lose all acceleration if going up a hill
Log may help but you'll need to know what to look for.
No codes or anything?
No codes at all.
that makes it really tough.
Any others report similar issues?
lose all acceleration up a hill seems to disappear if set in sports mode, next I will switch off the MDS with sports mode on/off.
Hi Mikel, any progress with adding the sports mode switched on all the time, this may help until I find a repair if any for the uphill loss of power?
No, you may want to look into a Tazer to accomplish that.
I run into the exact same problem with my JK 2011 sprintex supercharged. I have a couple emission codes that I can’t shake for some reason also. My Rpm gauge will skyrocket but there’s no power.
Amazing this is a known problem, and no one has a fix
- MagsTuning
Post a data log. It could be picking up some serious false knock and is pulling timing.typan wrote:Would data logging help out in finding the problem with my 300 SRT 2013, at around 60K and 1500 revs I lose all acceleration if going up a hill .I can press the pedal to the floor and nothing happens until suddenly it kicks in and takes off . Anyone having the same problem or have a fix?
