Restoring stock MAF transfer?
Juice
Post by Juice »
I would like to compare my stock airbox to my JLT CAI. My issue is my stock tune that I'm modifying with Intune already has the CAI added to it. I loaded the 91 octane performance tune (Without the CAI option) hoping it would load the stock MAF but it didn't.
Is there anyway this can be done from the handheld?
My car is a 2007 mustang that put a '13 Coyote in.
Re: Restoring stock MAF transfer?
You'll need a custom tune made with the stock transfer function.
Juice
Post by Juice »
Thanks Mike. I was afraid that was the case.
Post the backup from the tool and I can set the transfer function back to stock.
Juice
Post by Juice »
Here it is, thank you!
here you go.
Juice
Post by Juice »
mikel wrote:here you go.
P0605 on second start. :(
thats odd.
I went to turn it off but it says its already off, will need to dig into it.
Juice
Post by Juice »
mikel wrote:I went to turn it off but it says its already off, will need to dig into it.
Appreciate it Mike. But just to recap, 3 different tunes, this, canned 91, and an sct stock tune with just the gear ratio and P0460 disabled in it, All exhibit the same. P0605 code and power loss on top end. The only tune that runs proper is modifying my stock tune with the I2020.
Mike, Would it be easier to figure out why the catalyst monitor goes to "not avail' modifying the stock tune ?
That is the tune I'm currently running, and it is actually running very well with perfect drivability and good power.
And why I can't change cam timing...
