Saw PID Unlock
MyChallyNow
Saw PID Unlock
So I see a PID that says number of flashes since unlock. Does this mean that the PCM is Unlocked?
Re: Saw PID Unlock
where do you see this PID??
Was your pcm sent here to be unlocked?
MyChallyNow
Re: Saw PID Unlock
Car is not home right now...but under live with dataviwer open and i3I hooked up I saw this pid.
Car was at dealer recently and they hooked up and left running for about a half hour. I could not get a straight answer as to what was going on. Maybe curious about some data that the car had on board.
10 to 20 below ambient intake temperature readings recently when I was doing some testing.
So when I got home i hooked back up to i3 next day I did see that.
No i did Not send my PCM into you for unlock.
Re: Saw PID Unlock
Im not sure what you were seeing, but your pcm is indeed locked if it hasnt been sent in to be unlocked.
