not reading codes
kw5.9
not reading codes
Post by kw5.9 »
predator not reading codes and I have a check engine light on? feels like it running on 3 or 6 cylinder very very rough, I was able to floor it several times in nutrual and it seems to be alot smoother, I am back to stock and took off the boost fooler, and unpluged the puck and still the check engine lite is on? Please help...if any one can!
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
Herculou
RE: not reading codes
Post by Herculou »
kw5.9 wrote:predator not reading codes and I have a check engine light on? feels like it running on 3 or 6 cylinder very very rough, I was able to floor it several times in nutrual and it seems to be alot smoother, I am back to stock and took off the boost fooler, and unpluged the puck and still the check engine lite is on? Please help...if any one can!
Mine does the same thing, some codes it will read and some it won't . Have you done the KEY trick to get the codes? Turn the key to "run" 3 times and the codes will appear in the Odometer display.
You can try to clear the Try to clear the codes anyway. It might not read the codes, but it can still clear some of them.
06 CTD, AFE, 6 speed 3.73, predator
kw5.9
Post by kw5.9 »
Thanks, i will try now, but it will give me code how do determine what the code means? Thanks again help, I am contemplating going to dealer this afternoon.
Herculou
Post by Herculou »
http://www.cumminsforum.com/forum/115229-post5.html
This web site has a lot of the codes and what thay are....
kw5.9
I am worried
Post by kw5.9 »
I put my truck in the shop, I took off the programs,the boostfooler,and the puck, they told me cylinders 1,2,3 were not firing, they questioned me about the velcro on the fuse box, for the puck(i fogot to take off)they asked if I had any kind of box on the truck, I told them I was the only owner of truck and had never had a box on there, I revised the predator about 2weeks ago with the new revision so I hope key counts are not going to be an issue,but can any one give me some words of advise so when they trow questions at me I know what the answer needs to be.
Herculou
RE: I am worried
Post by Herculou »
with only 2 weeks of the new version your "key counts" are going to be low, they may ask about that. Tell them you reset the computer trying to fix the problem. I believe (but I am not positive) all you need to do for that is to disconnect the battery for a few (10-15) minutes.
kw5.9
Post by kw5.9 »
cool!, I hope that works.. Do you think they can really prove anything?
Herculou
Post by Herculou »
Not sure they could "prove" anything. If thay don't see it attached I don't see how they could...
kw5.9
Post by kw5.9 »
hopefully the ecm dosent show anything on there that they can hammer me on
