t2 EX
Drebuilders
Re: t2 EX
Post by Drebuilders »
so some time has gone by and I have found some more gauges that do not change. also I cannot find o2 Volts. I can send another parking lot recording and my info.xml if that is what is needed, other than that it has been working flawlessly. even have added a cmr tune to it, but without o2 feedback working I don't want to go too crazy with changing things
Re: t2 EX
O2 V shouldnt really be something moist tuners need that I would imagine. If the adaptives and fuel trims are there it should tell them what they need to know.
What PID do you see that does not change?
Drebuilders
Re: t2 EX
I am adding a nitrous system to my magnum this winter. using EAS power switch and 2 universal sensors. I have 2x wideband O2s, a fuel pressure and a nitrous pressure sensors to add. problem is I cant get my style or update agent to play nice with my t2. any ideas? ive tried two cables and both usb ports on my computer now im at a loss and don't quite know how to proceed.
sbenja2008
Re: t2 EX
Post by sbenja2008 »
Drebuilders wrote:I am adding a nitrous system to my magnum this winter. using EAS power switch and 2 universal sensors. I have 2x wideband O2s, a fuel pressure and a nitrous pressure sensors to add. problem is I cant get my style or update agent to play nice with my t2. any ideas? ive tried two cables and both usb ports on my computer now im at a loss and don't quite know how to proceed.
You might be better off not updating it because everytime I update mine something else goes wrong with it.
Drebuilders
Re: t2 EX
I still need to be able to add my universal input values, so with or without update I need my style
[/quote]
You might be better off not updating it because everytime I update mine something else goes wrong with it.[/quote]
Boys grow toys get more expensive
sbenja2008
Re: t2 EX
Drebuilders wrote:I still need to be able to add my universal input values, so with or without update I need my style
Even if you get it updated to use the EAS universal input values you wont be able to datalog the universal input values until Diablosport gets off their butt and comes out with a fix so the EAS system is able to show up in the datalog.
Re: t2 EX
Can you please post the info.xml file from the T2 drive so we can check this out?
Re: t2 EX
Actually, I figured out what was happening, please try updating it again when you have a moment and it should work fine.
FWIW mystyle is not used with T2 at all.
Drebuilders
Re: t2 EX
mikel wrote:Actually, I figured out what was happening, please try updating it again when you have a moment and it should work fine.
I will try again later, but the instructions that came with the universal input EAS states you need to map the 5v using my style... what am I supposed to do to map the 5v inputs?
Re: t2 EX
the scaling is done through the EAS setup menu on the device itself ;)
Drebuilders
Re: t2 EX
thanks mike, I will get into that part of the build soon I hope
Drebuilders
Re: t2 EX
just an update, the t2 updated without issue, and the EAS setup was super easy, much better than the my stlye! thanks mike for getting me straightened up!
You know... you don't have to log in the t2, other recording devices are out there if you aren't happy with diablos speed you can get one of those and log right now after you wire it all up.
