P600 check engine light code
Liston2015
I recently purchased unlocked pcm and tuner from diablosport. I have a check engine light code that won't come off. I've tried everything to clear it including trying to clear the code with a perfetional scan tool, truck runs good I just don't want to stare at it. Truck is a 2015 ram 2500 6.4 hemi. Code is a p600, which is a pcm code
- MagsTuning
Re: P600 check engine light code
Liston2015 wrote:I recently purchased unlocked pcm and tuner from diablosport. I have a check engine light code that won't come off. I've tried everything to clear it including trying to clear the code with a perfetional scan tool, truck runs good I just don't want to stare at it. Truck is a 2015 ram 2500 6.4 hemi. Code is a p600, which is a pcm code
Make sure your PCM connections are fully seated.
Liston2015
All connections are good, I've done everything I can think of, not sure what the problem is, probably will be calling Diablo in the morning, to see if I need to send pcm back, I appreciate the advice Mike, anything else you can think of would be great
can you post the info.xml file from the device please so I can look into this?
Liston2015
You might need to walk me through that one Mike not real sure on how to do that
connect the device to the pc and use the Upload Attachment option to grab the info file from the i3 drive.
