not reading codes
not reading codes
predator not reading codes and I have a check engine light on? feels like it running on 3 or 6 cylinder very very rough, I was able to floor it several times in nutrual and it seems to be alot smoother, I am back to stock and took off the boost fooler, and unpluged the puck and still the check engine lite is on? Please help...if any one can!
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
RE: not reading codes
Mine does the same thing, some codes it will read and some it won't . Have you done the KEY trick to get the codes? Turn the key to "run" 3 times and the codes will appear in the Odometer display.kw5.9 wrote:predator not reading codes and I have a check engine light on? feels like it running on 3 or 6 cylinder very very rough, I was able to floor it several times in nutrual and it seems to be alot smoother, I am back to stock and took off the boost fooler, and unpluged the puck and still the check engine lite is on? Please help...if any one can!
You can try to clear the Try to clear the codes anyway. It might not read the codes, but it can still clear some of them.
06 CTD, AFE, 6 speed 3.73, predator
http://www.cumminsforum.com/forum/115229-post5.html
This web site has a lot of the codes and what thay are....
I am worried
I put my truck in the shop, I took off the programs,the boostfooler,and the puck, they told me cylinders 1,2,3 were not firing, they questioned me about the velcro on the fuse box, for the puck(i fogot to take off)they asked if I had any kind of box on the truck, I told them I was the only owner of truck and had never had a box on there, I revised the predator about 2weeks ago with the new revision so I hope key counts are not going to be an issue,but can any one give me some words of advise so when they trow questions at me I know what the answer needs to be.
RE: I am worried
with only 2 weeks of the new version your "key counts" are going to be low, they may ask about that. Tell them you reset the computer trying to fix the problem. I believe (but I am not positive) all you need to do for that is to disconnect the battery for a few (10-15) minutes.
