Accidentally applied cruise control fix to unlocked PCM via micropod. When I tried to tune it the only choice I had was to restore backup. During restore failure occurs. I've updated the tool and did get a cal update request. However, since then I still get the error. Car cannot be driven.
Attached is "info.xml". Can anyone help so I can get driving again by morning?
Stuck in Recovery Mode - cannot be driven
Re: Stuck in Recovery Mode - cannot be driven
I was able to restore latest Chrysler cal through micro pod which made it drivable again.
However, toil is still in recovery mode. It downloads older cal update but then never installs it and it eventually disappears from the tool. Any thoughts or does this require a call Monday with tool in hand?
Yes, please give us a call so we can reset the device.
