Just installed a D7159 puck on my 04.5 Dodge 3500 Cummins diesel. Drove 1700 miles towing a fifth-wheel trailer with the puck on the lower (60HP) setting. The trip computer was giving me wrong mileage performance and distance to empty data. I compared the computer mileage performance to actual fuel usage.
When I returned the switch to stock position, I got accurate data from the trip computer. What gives?
Overhead Trip Computer
RE: Overhead Trip Computer
The DIC will often read wrong when a tune or inline device is altering fueling...
What causes ther wrong reading? Doesn't the trip computer continue to receive accurate fuel consumption and mileage data from the sensors? If the P{owerpuck causes wrong signals to be sent to the trip computer, does it not also cause wrong signals to be sent to the engine computer?
ohyeahfriday
Simply put, the trucks computer is being tricked by the Puck. The ECM is "tricked" by the Puck, as well as most boxes/programmers, because otherwise you would ever get the amount of fuel through the injectors that you need to see to make power. Right now, my overhead says that I am averaging 28-30 mpg, but I know better than to believe that.
To put it real simply, if you want to know your fuel economy, I suggest hand calculating, anything else will be flawed.
