Lost stock tune?
Mikepgp
Lost stock tune?
Post by Mikepgp »
2019 ram, did the pcm swap. Did modify stock, disabled mds. That’s all I wanted. Process worked fine.
Then, I got curious to try throttle booster.
Also, the i3 said it had a calibration update.
So, I plugged in, did the update, then decided to turn on throttle booster. Completed.
Decided after driving I didn’t like it, was too jumpy in backing out of space on parking lot, etc.
I plugged in, went to modify to turn throttle booster back to 0%, but modified was grayed out.
I had to do select tune all over, and it prompted be to first make a backup of the stock pcm before naming changes.
Which I already did days ago.
Why was it asking my twice? Did it “forget” I was tuned already?
At this point I just want to put it back to stock.
Throttle booster is not for me.
I did the restore it I think it restored the “2nd” backup with the throttle boost enabled.
Anyone know how I can just start with a factor fresh tune again and start over?
Re: Lost stock tune?
it cant save a tune as a backup, if it restored, it put the stock file back 100%
Post the info.xml file from the device so I can confirm.
Mikepgp
Post by Mikepgp »
Mikepgp
Post by Mikepgp »
xml file
Mikepgp
Post by Mikepgp »
tunes
its tuned to pcm and tcm, and should allow you to return to stock at any point if thats what you want to do.
It simply cant save a tune that was written by this device as a backup or 'stock tune'.
