2016 Camaro SS AFM
Jvcamaro6
2016 Camaro SS AFM
Post by Jvcamaro6 »
Hello, I have a Trinity T1000 with 1R14B revision on it. I uploaded a 91 Octane tune with a hard shift trans tune, but it doesn’t seem to turn off my AFM? The light goes green and shows V4 mode still, I tried with a modified stock tune and it does the same thing. Do you know what’s going on? Thanks
Re: 2016 Camaro SS AFM
you are selecting the option for AFM off then installing the tune after that?
if souse the DSDownloader to export the last tune written and post it here.
it doesn't get disabled automatically man... you have to select to Modify the 91 octane tune and disable the setting yourself, and then install the tune...
Jvcamaro6
Post by Jvcamaro6 »
I am modifying the tune and selecting AFM/DOD off in the engine parameters. I have changed the tune 3 times to try and see what the problem was. Still goes into V4.
Jvcamaro6
Post by Jvcamaro6 »
PCM_673677677821_Modify_Stock_Tune_modified.grg
(3.25 KiB) Downloaded 435 times
Jvcamaro6
Post by Jvcamaro6 »
TCM_281915281926_Trans_Hard_Shift_Tune_modified.grg
(11.25 KiB) Downloaded 447 times
I dont recall f this was a bug on that application, but it was not off.
Load the attached custom tune and it will be disabled.
PCM_673677677821_afm.grg
(110.5 KiB) Downloaded 388 times
Jvcamaro6
Post by Jvcamaro6 »
Thank you so much highly appreciated!
Return to “Trinity GM Gas”
